How can I display hidden files in Windows XP??????
gani
Newbie level 6
Hello everybody,
my problem is that i can't see my hidden files
and if i click the option 'show all hidden files' after clicking ok .it is unable to view hidden files . and when done to do the same ..
the radio button will be agin in 'don,t show hidden files '
What should I do?? Please help me and mail me to ganice@rediffmail.com
Thanks you.
seems like ur computer has any spy... scan ur computer ..
thank you....i solved my problem by changing registry setting
@gani
how did you solve the problem... pl tell me the procedure...
i too suffer from the same problem..
I had this problem and it was a VIRUS !
So, you have to download updates and scan you PC.
hello
check out this....it may solve your problem...even i followed the same steps...
goto run n type regedit and follow these steps...
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL
DELETE the value CheckedValue in the right window. (Its type should be REG_SZ and data should be 2.)
Now create a new DWORD value called CheckedValue (same as above, except that the type is REG_DWORD). Modify the value data to 1 (0x00000001).
This should let you change the "Hidden Files and Folders" option.
This registry hacking is unnecessary. Just open windows explored, click on tools, folder option tabs, and select Show hidden files and folders. Done.
thank you...i solved my problem
just update your unti virus and scan your pc every thing will be ok
