HFSS mesh generation problem
winglj
Full Member level 4
hfss mesh generation
Hi. I have a problem when I run HFSS to simulate an antenna. The geometry is imported by STEP file. But when I run the simulation, there are some contact and proximity error found.
The errors discription are:
Proximity:
Vertex-Face
Vertex ambiguously close to existing triangle
Contact:
Small triangle
This triangle is very much smaller thanthe largest triangle on this face
Small edge
This surface triangle edge is much smaller than the largest edge on the face
Are they related to the mesh generation? How can I fix it? Thanks in advance, any help will be appreciated.
sunyvel
Junior Member level 3
mesh generation hfss
try using hfss scrips to do the simulations. it will work out......i had the same problem and the scripts helped a lot
gunajraman
Member level 2
Might be due to improper contacts between parts of your geometry.
Check all the coordinates and make sure the geometry is connected and doesnt overlap. As overlaps may lead to huge meshing around that place.
sayan4
Newbie level 5
Excuse me,I have the same problem and I'm becomig crazy.
What are hfss scripts?
SparamGuru
Newbie level 3
If you are using version 10, try the heal option in 3DModeler->Model Analysis->Heal.
Hope this helps.
ppAntenna
Member level 1
Hi winglj,
Can u upload yr geometry?
Maybe we can fix it and post back to u.
:D
jjantenna
Member level 2
I got the same problem too. If there is any better way to deal with the problem of imported structure, please share with us.
Thanks!
