Help needed extracting ISO file?
btbass
Advanced Member level 5
Oberon
I have a couple of ISO files which I can't extract?
I have ISO buster, but when I extract them I end up with a bin file or a tao?
What do I do?
jzaghal
Full Member level 2
Try using WinISO.
Good Luck.
g_iftah
Junior Member level 3
Israel
hi,
tray using alchol 120%
iftah
Kaleem
Member level 1
It might help a lot of you that even WinRAR can extract the iso files quite reliably.
cedance
Advanced Member level 2
Germany
hi,
actually, why do u want to extract an ISO file? u could emulate it on an image drive using the softwares already mentioned above... alchohol 120% is my choice too.
incase u extract/emulate the ISO and still land up with a bin file, then its doubly imaged. first bin file and then ISO. along with the Bin file will be a *.cue file. just open alchohol 120% and then point to the cue file. it ll get added there.. and then right click on it and emulate. hope this clears the doubt!
/cedance
V
v_naren
What do I do?
forget everything else
just install Daemon tools's virtual CD and mount ur .ISO file and u will be able to see the contents of ur ISO file. then copy the contents into ur hard disk and use them as u wish.
ghbolivar
Full Member level 1
try using Ultraiso (Windows XP)
on linux:
mount -r -t iso9660 -o loop /home/usuer/image.iso /mnt/cdvirtual
enjoy
attylus76
Junior Member level 2
You can use the virtual disk of nero in order reading yours * ISO and therefore you can extract the content.
