walker5678
Full Member level 3
Is this method OK?
Attached file is an amplifier diagram, in which the IN+ bias voltage is generated by the resistor devider. When there is supply voltage variation, the IN+ will variate, and thus make PSRR bad.
I think about a method to add a W/L=1u/100u PMOS as a large resistor between the 1uF bypass capacitor and the VDD/2, so the variation of bypass capacitor voltage will reduced much, and so as to enhance PSRR performance.
Is this method OK?
thanks
Is this method OK?
thanks
