Help me fix an error in code for adder 4bit
boyzzun
Junior Member level 1
hi guys.i wrote code for adder 4 bit using '+" and '&' ,and i have error like this
PHP:
library ieee;
use ieee.std_logic_1164.ALL;
use ieee.std_logic_arith.ALL;
use ieee.std_logic_unsigned.ALL;
entity add4 is
generic (N: natural := 32);
port ( A : in std_logic_vector(2 downto 0);
       B : in std_logic_vector(2 downto 0);
	   Cin : in std_logic;
	   Sum : out std_logic_vector(2 downto 0);
	   Cout : out std_logic
end add4;
architecture dataflow of add4 is
signal A1 : std_logic_vector(3 downto 0);
signal B1 : std_logic_vector(3 downto 0);
signal Sum1: std_logic_vector(3 downto 0);
begin
 A1 <= '0' & A;
 B1 <= '0' & B;
 Sum1 <= A1 + B1 + Cin;
 Cout <= Sum1(3);
 Sum <= Sum1(2 downto 0);
end dataflow;
and this is test
PHP:
library ieee;
entity test_add4_gen is
end test_add4_gen;
architecture test of test_add4_gen is
component adder is
	   Cin : in std_logic;
end component adder;
signal A1 :std_logic_vector( 3 downto 0) :="0110";
signal B1 :std_logic_vector( 3 downto 0) :="0101";
signal Cin : std_logic;
signal Sum1 :std_logic_vector(3 downto 0);
signal Cout :std_logic ;
begin
add: component adder
     generic map (32)
       port  map (A, B, Cin, Sum, Cout);
end test;
and error
PHP:
# ** Error: test_add4.vhd(23): (vcom-1027) Number of positional association elements (1) exceeds number of formals (0).
# ** Error: test_add4.vhd(24): (vcom-1136) Unknown identifier "a".
# ** Error: test_add4.vhd(24): (vcom-1136) Unknown identifier "b".
# ** Error: test_add4.vhd(24): (vcom-1136) Unknown identifier "sum".
how can i fix this error
when you instantiate a component, if you have created a component for it (you do not need to declare the component btw), you simply instantiate it like this:
add : adder
generic map (....etc
PS, I notice in your component you have no generic, but on the entity you do. You wil need to fix this or you will get an error when you try and map the component to the entity (hence why components are fairly redundant).
Direct instantiation is done like this:
add : entity work.adder
generic map (
...etc
for the other errors, you have used positional association with signals that do not exist. in your testbench the signals are A1, B1 etc, so the map should be:
add : adder
generic map (32)
port map (A1, B1, Cin, Sum1, Cout);
but even better, used named association:
generic map (N => 32)
port map(
  A => A1,
  B => B1,
  Cin => Cin,
  Sum => Sum1,
  Cout => Cout
add : adder
generic map (
...etc
add : adder
generic map (32)
port map(
  A => A1,
  B => B1,
  Cin => Cin,
  Sum => Sum1,
  Cout => Cout
still error,i do as you say,could y check and test them ?????
