THREEINCHNAIL
Newbie level 3
Codes help
I want to learn using textio. Here I use Read data from scr.txt to IP
core RAM and Write them to the text1.txt. I wrote the codes here but
it doesn't work. Any suggestions about this is very appreciated.
One more thing, when i use Modelsim to Run by step. It always gives the
error information and cannot finish the simulation. I don't what it
means.
Trace back: Error opening C:/Documents and Settings/zq500/Local
Settings/Temp/xil_1700_6
# while executing
# "error $winName"
# (procedure "view" line 82)
# invoked from within
# "view source"
# (procedure "vsimcmd::viewProcessSource" line 2)
# "vsimcmd::viewProcessSource /check/uut/u0/select_outputb"
# ("after" script)
# 2: ::tkerror {Error opening C:/Documents and Settings/zq500/Local
Settings/Temp/xil_1700_6}
# 1: ::bgerror {Error opening C:/Documents and Settings/zq500/Local
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
use ieee.std_logic_textio.all;
use std.textio.all;
entity check is
end check;
architecture serial of check is
component checkram
port (
addra: IN std_logic_VECTOR(2 downto 0);
addrb: IN std_logic_VECTOR(2 downto 0);
clka: IN std_logic;
clkb: IN std_logic;
dina: IN std_logic_VECTOR(7 downto 0);
doutb: OUT std_logic_VECTOR(7 downto 0);
wea: IN std_logic);
end component;
signal addra: std_logic_vector(2 downto 0):=(others=>'0');
signal addrb: std_logic_vector(2 downto 0):=(others=>'0');
signal dina: std_logic_vector(7 downto 0) :=(others=>'0');
signal doutb: std_logic_vector(7 downto 0) :=(others=>'0');
signal wea: std_logic :='1';
signal wrd: std_logic :='0';
signal clk : std_logic :='0';
signal reset: std_logic :='1';
file from_file:text open READ_MODE is "src.txt";
file to_text:text open WRITE_MODE is " text1.txt";
begin
UUT:checkram port map
addra => addra,
addrb => addrb,
clka => clk,
clkb => clk,
dina => dina,
doutb => doutb,
wea =>wea
clock_process: PROCESS
BEGIN
clk <= NOT (clk);
WAIT FOR 5 ns;
END PROCESS clock_process;
reset <= '0' after 5 ns;
ramRd: process (clk,reset)
variable buf_out:line;
variable num: std_logic_vector(7 downto 0):=(others=>'0');
variable iptaddr: std_logic_vector(2 downto 0):=(others=>'0');
begin
if reset='1' then
iptaddr :=(others=>'0');
elsif clk'event and clk='1' then
while not (endfile(from_file))loop
READLINE(from_file,buf_out);
READ(buf_out,num);
WRITE (buf_in,doutb);
WRITELINE(to_text,buf_in);
wea <='1';
addra<=iptaddr;
dina<= num;
iptaddr:=iptaddr+"1";
end loop;
end if;
end process;
addPro: process (addra,reset)
begin
if reset='1' then
wea<='1';
wrd<='0';
elsif addra = "111" then
wea<='0';
wrd <='1';
end if;
end process;
output: process(clk,wrd,reset)
variable buf_in:line;
begin
if reset='1' then
addrb <=(others=>'0');
elsif clk'event and clk ='1' then
if wrd <= '1' then
addrb <= addrb+"001";
end if;
end if;
end process;
end serial;
means.
# while executing
# "error $winName"
# "view source"
# ("after" script)
library ieee;
use std.textio.all;
entity check is
end check;
component checkram
port (
clka: IN std_logic;
clkb: IN std_logic;
wea: IN std_logic);
end component;
begin
addra => addra,
addrb => addrb,
clka => clk,
clkb => clk,
dina => dina,
doutb => doutb,
wea =>wea
BEGIN
clk <= NOT (clk);
WAIT FOR 5 ns;
begin
if reset='1' then
READ(buf_out,num);
wea <='1';
addra<=iptaddr;
dina<= num;
end loop;
end if;
end process;
begin
if reset='1' then
wea<='1';
wrd<='0';
wea<='0';
wrd <='1';
end if;
end process;
begin
if reset='1' then
if wrd <= '1' then
end if;
end if;
end process;
end serial;
