Pancra85
Junior Member level 1
I want to build a drum sequencer with Arduino, and want analogue sounds. I've come across this schematic for the Korg Monotribe rhythm section (drums): http://www.korg-datastorage.jp/Manual/monotribe_sch.pdf
I think I am familiarized enough with the Arduino board to do it but I don't quite understand the drums schematic.
I know the BD, SD, HH and Noise labels on the left is where I need to send some kind of signal in order for the circuit to produce the corresponding sound (Bass Drum, Snare... etc)
A few questions:
Where it says HH Out, SD Out, etc... is the sound output? What are the nodes that say SD Decay and such, maybe you can control the decay by placing a potentiometer there? What are the labels on the right that say Rhythm and Port for? And what transistor should I use for the Qs?
Thank you!
A few questions:
Thank you!
