I have just installed IC50 on redhat8, everything seems to be OK, except this problem,
In the stimulus option window, I can't select files in the list box by double clicking any files. every time I click a object, nothing happened. So I have to type the path&file name manually.
what caused this happen, did I do something wrong?
this is the snapshot:
i had some strange problems with ic5 under suse8.2 (total crash when executing spectre simulation).
but someday i logged in as root and started ic5 and everything was ok, so it was a problem of data access rights. maybe you have the the same problem. Try to logg in as root.
Below is the recommended OS patches for Linux by cadence customer support, but anyway i don think it is an OS problem.
regards,
Linux
RH 7.2 All Mandatory
with errata updates dated
(Apr 14, 2003) kernel-2.4.18-27.7.x.i386
kernel-bigmem-2.4.18-27.7.x
kernel-BOOT-2.4.18-27.7.x
kernel-debug-2.4.18-27.7.x
kernel-doc-2.4.18-27.7.x
kernel-smp-2.4.18-27.7.x
kernel-source-2.4.18-27.7.x
kernel-utils-2.4-8.13.7.2
glibc-2.2.4-31.i386
glibc-2.2.4-31.i668
glibc-common-2.2.4-31
glibc-devel-2.2.4-31
glibc-profile-2.2.4-31
gcc-2.96-112.7.2
gcc-c++-2.96-112.7.2
gcc-chill-2.96-112.7.2
gcc-g77-2.96-112.7.2
gcc-java-2.96-112.7.2
gcc-objc-2.96-112.7.2
Although you can install some OS package to fix this problem , i still recommend you not use it on the version newer than Redhat 7.3 . Most of the EDA can be runs well on Redhat 7.X and most of EDA provider only gurante on that .
no what is happening is that part of the openwindows server chooses a font of size 0, so it has nothing to put there, and nowhere to put it. check to see if you get hundreds of warnings every time you click and "nothing happens".
read up on some old posts i made - the only info i could get is because netscape does the same thing, which kind of made a whole version of netscape usesless on these openwindows drivers.
sure-fire fix... send RH8 back to hell where it came from, get SuSe 8.2 or RH7.3.. No just kidding about RH8, seems Cadence should have rebuilt to avoid the mistake like Netscape did..
