sram layout
I am doing a layout for SRAM. Each cell has six transistors. I finished the layout for a single cell. I understand that I can flip the cell in such a way to share the well and diffusion to make the layout more compact.
But the problem, will there be any latchup problem after it is manufactured, since those cells are so close? Do you know if there is any isloation between those cells? Technology we are using TSMC0.3, 5 melts, 1 poly. Thank you very much for your reading this.
