fanios
Newbie level 6
- Joined
- Dec 8, 2010
- Messages
- 12
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,366
Hi to all .I try for two months to make ad work .I just use my spi controller . My vhdl script is exactly as timing diagrams chapter 9, ug334 . Is there anything that is not metioned in manual that creates problems such as desabling other spi devices..It is not mentioned . i change spi_sck frequency and have different results. why? i just tried to check gain. So , firstly i make amp_cs low and give the same time spi_mosi the 8th bit of gain so on the first rising edge of spi_sck amplifier captures it . and i capture amp_dout also on rising edge of spi_sck and so goes on until capture all bits. The results that i get on leds depend only of frequency . If frequency is greater than 1mhz all leds light , else two leds , five leds depending on frequency ... Also timing diagrams for ltc1407a are different in manual ug334 and manual for the ltc . Spi_sck is '0' at sample points or not? Also for connecting a dc source do i need something else than vina and gnd pin?
If someone could help me ..thank u
