May 13, 2008 #1 L LinXiaoling Member level 1 Joined Feb 25, 2008 Messages 32 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 1,490 when including the IO PAD module ,the delay for some pad (e.g. reset_pad)is too large in critical setup timing path .Therefore,the violation is too large.can anyone help me? Thanks!
May 19, 2008 #2 L LinXiaoling Member level 1 Joined Feb 25, 2008 Messages 32 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 1,490 can anybody give me a hand?
May 19, 2008 #3 L ljxpjpjljx Advanced Member level 3 Joined May 5, 2008 Messages 968 Helped 80 Reputation 162 Reaction score 56 Trophy points 1,308 Location Shang Hai Activity points 4,679 you can exclude this pad for STA~
May 19, 2008 #4 sree205 Advanced Member level 1 Joined Mar 13, 2006 Messages 453 Helped 58 Reputation 116 Reaction score 25 Trophy points 1,308 Activity points 4,420 like setting it as a false path ?
May 20, 2008 #5 L LinXiaoling Member level 1 Joined Feb 25, 2008 Messages 32 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 1,490 thanks very much! but I will try and see if it will effect the backend design and I hope there is another way to fix it.
May 20, 2008 #6 R risccpu Junior Member level 2 Joined Oct 21, 2005 Messages 21 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,421 You need to confirm with the datasheet of IO PAD usage and set the according constraints in sdc.
May 20, 2008 #7 L LinXiaoling Member level 1 Joined Feb 25, 2008 Messages 32 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 1,490 do you mean that I just sythesis the core ,then change the SDC according to the IOPAD datasheet during placement process?
