Gm/IDS vs Vov plot in Cadence?
dtzounakos
Member level 3
My question is how to plot gm/ids vs Vov in Cadence. I know how to plot gm/ids vs
vgs but i don't know how to define custom equation in calculator such as Vov=Vgs -Vth!
Does anyone know how to do this?
Thanks a lot!
JoannesPaulus
Advanced Member level 3
USA
to plot a waveform versus any equation you should plot both in the same waveform window then go to the axes menu and in the "Plot vs." scroll down menu, choose your equation.
I hope it helps!
dtzounakos
Member level 3
Thanks a lot. But what i ask is how to define Vov=Vgs-Vth in ordr to plot gm/Ids vs Vov! If you how to to define Ids/(W/L) in order to plot Gm/IDS vs Ids/(W/L) I will appreciate it!!
Thanks!
Added after 3 minutes:
Thanks a lot! But what i ask is how to define Vov=Vgs-Vth (in waveform calculator i suppose) in order to plot Gm/Ids vs Vov! Also, if you know how to define IDS/(W/L) in order to plot Gm/Ids vs Ids/(W/L), I will appreciate it!!
Thanks!
Thanks a lot! But what i ask is how can i define Vov=Vgs-vth (in waveform i suppose) in order to plot Gm/ids vs Vov!Also, i will aprreciate it if you know how to define IDS/(W/L) in order to plot Gm/IDS vs IDS/(W/L).
Thanks!
JoannesPaulus
USA
In the calculator click on OP and then select the transistor you want to know the VTH. A pop-up window will appear. In the scroll down menu of the new window look for VTH. You can then use that in your equations.
