gal16v8-Atf16v8b Help needed
erdilmen
Newbie
Hello all to Dear friends
Im trying to copy a gal16v8
i read file with top programmer but im not sure its copy protected or not.
also i need to help convert this file to jedec.
  • ic 1.rar
Any GAL programmer that I have seen so far was able to write .jed files. How can we know what your so-called bin file (actually ASCII text) means? What is "top programmer"? Please give a link to the manufacturer and user manual.
Your programmer (software) should be able to read the chip and write a .jed file to the HDD.
im reading with top3000 its saving hex file not jed file.My friend should write file (far from me) with ttl866 is asking jed file.
According manual it should be able to save as .jed file.
Just choose .jed as file format.
I recommend to read the manual, or use the "help".
Maybe you need to use "save as" or similar.
If you need more detailed help you should provide more detailed information.
Like: software name, software version, screenshots...
at my programmer there os no way to save it as jed file
its reading like that,but saving as jed
Are there anyway to save it as jed?
Is this reading copy protected or not?
L0000 11000000000000000000000000000000
L0032 11000000000000000000000000000000
L0064 01000000000000000000000000000000
L0096 11000000000000000000000000000000
L0128 11000000000000000000000000000000
L0160 01000000000000000000000000000000
L0192 01000000000000000000000000000000
L0224 01000000000000000000000000000000
L0256 01000000000000000000000000000000
L0288 11000000000000000000000000000000
L0320 01000000000000000000000000000000
L0352 01000000000000000000000000000000
L0384 01000000000000000000000000000000
L0416 01000000000000000000000000000000
L0448 01000000000000000000000000000000
L0480 01000000000000000000000000000000
L0512 01000000000000000000000000000000
L0544 01000000000000000000000000000000
L0576 01000000000000000000000000000000
L0608 01000000000000000000000000000000
L0640 01000000000000000000000000000000
L0672 01000000000000000000000000000000
L0704 01000000000000000000000000000000
L0736 01000000000000000000000000000000
L0768 01000000000000000000000000000000
L0800 00000000000000000000000000000000
L0832 00000000000000000000000000000000
L0864 00000000000000000000000000000000
L0896 00000000000000000000000000000000
L0928 00000000000000000000000000000000
L0960 00000000000000000000000000000000
L0992 00000000000000000000000000000000
L1024 00000000000000000000000000000000
L1056 00000000000000000000000000000000
L1088 00000000000000000000000000000000
L1120 00000000000000000000000000000000
L1152 00000000000000000000000000000000
L1184 00000000000000000000000000000000
L1216 00000000000000000000000000000000
L1248 00000000000000000000000000000000
L1280 00000000000000000000000000000000
L1312 00000000000000000000000000000000
L1344 00000000000000000000000000000000
L1376 00000000000000000000000000000000
L1408 00000000000000000000000000000000
L1440 00000000000000000000000000000000
L1472 00000000000000000000000000000000
L1504 00000000000000000000000000000000
L1536 00000000000000000000000000000000
L1568 00000000000000000000000000000000
L1600 00000000000000000000000000000000
L1632 00000000000000000000000000000000
L1664 00000000000000000000000000000000
L1696 00000000000000000000000000000000
L1728 00000000000000000000000000000000
L1760 00000000000000000000000000000000
L1792 00000000000000000000000000000000
L1824 00000000000000000000000000000000
L1856 00000000000000000000000000000000
L1888 00000000000000000000000000000000
L1920 00000000000000000000000000000000
L1952 00000000000000000000000000000000
L1984 00000000000000000000000000000000
L2016 00000000000000000000000000000000
L2048 00000000000000000000000000000000
L2080 00000000000000000000000000000000
L2112 00000000000000001111111111111111
L2144 11111111111111111111111111111111
L2176 111111111111111100
i find a way to save it as jed file but now its giving checksum error.
  • c1 jed.rar
The file doesn't correspond to specified .jed format
Generated by Topwin Ver8
GAL16V8
*L00000 11000000000000000000000000000000
The asterix is expected at the line end.
The shown fuse map is almost empty, but not completely. It doesn't look like the readout of a protected device, but neither like a meaninful logic description. Or does the application suggest a mostly empty fuse map?
ALL GAL families have copy protection. Any designer will activate protection of his product.
I do have copied protected PLDs and CPLDs, but it requires a fully working PCB, Schematic extraction of PCB if it is not available, and then by trial and error, recreating (not coping by a programmer) a PLD equivalent PLD file
[moderator action: removed private eMail]
