Free 2D or 3D simulator, hyperlynx
doofus32
Junior Member level 2
2d bus simulators
Does there exist any free PCB (2D or 3D) for simulating current, voltage and/or electromagnetic?
How much does hyperlynx cost? Can Hyperlynx simulate an PCB boards that are made of Pads? Or does it only simulate pre models?
how much does hyperlynx cost
HyperLynx can import a board layout from PCB tools such as PADS. See the data sheet:
https://www.mentor.com/products/pcb/analysis_verification/hyperlynx/
I'm afraid HyperLynx is outside your "free" category. I saw prices a couple of years ago. HyperLynx EXT costs roughly $18K US. HyperLynx GHz is around $47K US.
hyperlynx prices
Yes, I was afraid I did remember those number. When I read the topics on this forum I se a lot of talk about HyperLynx, some I had hoped that it was some cheaper.
Any other program? Is HyperLynx an often used program?
3d hyperlynx
If your designs haven't high speed buses or signals, you probably never ever listen about HyperLynx.
If you have 33MHz PCI bus you can still have successful design without verification.
But if you have 2 or more SDRAM chips running over 70-80MHz, you are in the "dark side" and "things" become happened. Of course, you can still have working designs, but is possible to reach falls from board to board (manufacturing tolerances) or from chip supplier to chip supplier.
If you have complex boards with high speed buses (one or more), HyperLynx must be at least pre-route constrains determination.
So, the answer is "depend of your designs".
