[SOLVED] Fraction-N frequency divider
B
bjwlgh
Newbie level 1
fraction frequency divide
Can someone give me some vhdl source code about Fraction-N frequency divider.
This one takes 3 flip flops and two two-input gates.
The output will have no jitter, provided that the input clock has a
50% duty cycle and the routing delays from the flip flops to the
output gate are matched.
library ieee;
use ieee.std_logic_1164.all;
entity divide1_5 is
port (
gsr : in std_logic;
clk : in std_logic;
divided_clk : out std_logic
end entity divide1_5;
architecture rtl of divide1_5 is
signal Q : std_logic_vector(1 downto 0);
signal Q_f : std_logic;
begin
-- divide by 3 counter
divide_by_3 : process (gsr, clk)
begin
if gsr = '1' then
Q <= (others => '0');
elsif rising_edge(clk) then
Q(0) <= not Q(1) or not Q(0);
Q(1) <= Q(0);
end if;
end process divide_by_3;
-- Delay Q1 by half a clock
falling_ff : process (gsr, clk)
begin
if gsr = '1' then
Q_f <= '0';
elsif falling_edge(clk) then
Q_f <= Q(1);
end if;
end process falling_ff;
-- combine the rising and falling edge triggered signals
-- to give an output that has a 1/3 duty cycle, and
-- a frequency of the input clock / 1.5
divided_clk <= Q_f and Q(0);
end architecture rtl;
And other sourse:
Thank you very much,btw can you give some articles about it.
Hi, bjwlgh:
If you don't care about the output duty cycle isse,
you can try to write a auto-reloaded counter.
flowers
