fpga + software radio
shevy24
Newbie level 3
Hello
I am new to this forum and I need a help about this project "software radio using warp fpga board v2.2" I have started reading the documentation on the board manufacturer site :Mango Communications | WARP MIMO Kit v2, but still I don't understand the programming part after downloading the xilinx studio IDE, the software radio must be able to use MIMO technology. Please I will be glad if I can get a guideline on how to start the programming part..thanks :cool:
shevy24
Newbie level 3
Thanks for the info, I think I will go through the links and see if they help but I am meant to programme in xilinx environment, if you get something close to how to programme on xilinx it will be highly appreciated...
mrflibble
Advanced Member level 5
The virtex-4 on the board has to be programmed with a bitstream of your design. Usually one makes such a design in either verilog or vhdl. Hence the links...
Doesn't really matter if you use a xilinx or altera or whatever. The need for picking a language remains the same.
Also, doesn't the vendor of this board provide some example projects?
shevy24
Newbie level 3
There is no example project in the vendor website, it is only some libraries and codes they cam ewith the user guide, but I will try to the links you sent and figure out to use vhdl or verilog fo rbitstream of my design. I f I am stucked, I can contact u again..
thanks
shevy24
Newbie level 3
I finally got the example projects but I still have a problem where I can download EDK, I was aked to download the IDE to use which is tortoise SVN but still don't know where to download EDK
thanks
alainsan
Junior Member level 2
Maryland, USA
