jimito13
Advanced Member level 1
sutapanaki : Vdsat is defined by the model that "runs" behind a design kit.For example for my process the model is a version of BSIM,so i searched for the Berkeley's manual and i found the definition.It's rather complicated,so i run some parametric simulations with Id vs. Vds (with Vgs parameter) and i saw that the transition from triode to saturation region comes exactly at the point that is defined by the Vdsat parameter of cadence dc operating point results.For long channel devices i have read that Vdsat=Veff=Vod=Vgs-Vth but for short channel devices the definition is different and i suppose is the one defined in each model's manual.In order to be on the safe side i leave a margin of above 50mV (100mV to be absolutely sure as you say!).
steadymind : Many Thanks for the paper.I found it and i am reading it now.
