floating well PAD ESD problem?
gsheng
Junior Member level 2
when PD/ND mode, there are two paths from pad to Vdd,
(1) PAD->NMOS->VSS->VSS ESD BUS-> Vdd to Vss NMOS(or diode)->Vdd;
(2) PAD->foating well of PMOS ->Vdd;
I don't know which path is the main path. does path 2 exist?
why not add a pmos for the charge from PAD to Vdd?
Because the pad is like 3.3V torlance 5V PAD.
Added after 2 hours 5 minutes:
We can not only connect PMOS's bulk to core vdd. Otherwise it will leackage through juntcion diode.
I think if PAD has a negtive ESD voltage,then path (1) is active,else if postive voltage,path (2) is active,right?
In case of tolerant I/O ( floating nWell structure), there is no path of pad to vdd .
so path (1) is just available.
Do you mean path(2) is available? I do want to know why?
LaTeX Commands Quick-Menu:
