difflvl
I had a device that was failing with the conducted emissions test of the FCC part 15b.
It was failing in the 800khz-1.2MHz range. I do not have a clock source of that frequency on my board, nor was I able to trace where it is coming from.
My question is this what can I add to my power supply circuit to reduce noise in the 1MHz region.
I have attached my power supply schematic below. It is a 3.3 V regulator with VIN being a 6volt wall wart.
Thanks
Thanks
