recently i design a switched-capacitor circuit in tsmc 0.18um, in the circuit a CMOS transmission gate connect to PAD and an OPAMP input (high impedence), the switch size is << ESD protection mos in PAD, do the small swith need
obey ESD rule? for example, enlarge contact to poly distance ...
thank you very much!!
If you have already analog IO with a ESD protection before internal switch then nothing needed else,- IO incorporates all necessary structures to bypass a discharge current through themself. If switch is connected to pure bond pad directly, then you have to follow a fab ESD design guidelines.
You will need ESD protection on the input since right now you do not have safe path to VDD/GND for ESD pulse. You should add RPO (silicide block) layer on the drain side of your MOS but it will slightly increase its resistance so might degrade the perfromance.
In your case might be the safest way to add some schotky diodes to gnd and vdd . But agin it adds capacitance....
connecting an I/O pad to a MOSFET gate requires CDM protection in deep-submiron processes, which is usually implemented as a small resistor (50-200 Ohm) followed on the gate side by HBM diode protection (e.g. reverse diodes to power/ground)
your input CMOS switch is already implementing a small version of this CDM protection by adding channel resistance and diode to supplies through the S/D to body junction diodes, they will be small by ESD standards by it is a lot more protection than having nothing at all
You have to balance the analog performance with the yield problems ensuing from ESD sensitivity, this depends on the target application (market or research) and your specs
may not obey the ESD rule. Yet the ESD structre is supposed to be rail-based. for example, the 2 diodes are used in analogy pad. what's impoart, the ESD clamp used between power and gnd is supposed to work on normal state during ESD.
And lots of such clamps are supposed to be used.
