ESD diodes: do they need any guardring ?
DoYouLinux
Full Member level 1
esd guard ring
Hi all,
I am trying to design my own ESD protection pads using two basic diodes. Do I need to place any guardring close to the diodes. My diodes are Nwell diodes.
Thank you very much
DYL
esd double diode esd substrate connection
You need the guard ring to prevent latch-up problem.
need of guard ring
Thanks a lot, Fom and hung wai ming :)
By the way, for the guard ring, should it be the "P-tap" connected to the "Ground" ?
how+guard+rings+help+in+esd
usually for ESD device, you need guard ring, and some times even double guardring for two reason:
1. guard ring with enough contact and metal connection can help distribute ESD zapping current, sometimes current flows more through the guardring than from the substrate.
2. isolate the noise introduced by the diode under normal operation, since IO signal may easily have negative glitch, and will introduce noise into substrate without guardring the collect the carrier current.
but the distance of double guardring need to be controlled well since it can easily form a collateral npn transistor. and without enough conatct or strong metal power bus on top of metal ring, it will be less effective.
guard ring esd diodes
Thank you very much, mdcui :)
For double guarding, you mean, one is "p-sub" contact connected to ground and the other one is "n-well" contact connected to Vdd, right ? If so, for the latter one, I need to draw N-well all around the diodes and connect the N-well to Vdd. Am I correct ?
back to back diodes in esd
i think u r correct.
LaTeX Commands Quick-Menu:
