error in a matrix code
mostafa ahmed
Member level 1
Egypt
Dear All,
I'm a beginner in VHDL language. I already tried to write a simple code for complex number a matrix. But the problem I found a strange error. I tried to search for this error but I didn't find exact solution.
My program is
PHP:
-- Company:
-- Engineer:
-- Create Date:    10:26:17 01/14/2013
-- Design Name:
-- Module Name:    code_ver1 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.math_complex.all;
use IEEE.math_real.all;
use IEEE.numeric_std.all;
use IEEE.std_logic_textio.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity code_ver1 is
    Port ( e : in  STD_LOGIC;
           clk : in  STD_LOGIC;
           c : out  STD_LOGIC);
end code_ver1;
architecture Behavioral of code_ver1 is
	Type matrix Is Array (0 To 7) OF complex;
	signal v_matrix : matrix;
	Type pulses Is Array (0 To 7, 0 To 5) OF std_logic;
	constant pulses_matrix : pulses:=(('0','0','0','1','1','1'),('1','0','0','0','1','1'),('1','1','0','0','0','1'),('0','1','0','1','0','1'),('0','1','1','1','0','0'),('0','0','1','1','1','0'),('1','0','1','0','1','0'),('1','0','0','1','0','0'));
--	signal a, b : complex :=(0.0,0.0);
begin
process (clk)
begin
v_matrix(0)<=(0.0,0.0);						-- v0 = 0;
v_matrix(1)<=(133.3333,0.0);				-- v1 = 2/3*Vdc
v_matrix(2)<=(66.666667,115.470054);   -- v2 = 1/3*Vdc + 1j*sqrt(3)/3*Vdc
v_matrix(3)<=(-66.66667,115.470054);   -- v3 = -1/3*Vdc + 1j*sqrt(3)/3*Vdc;
v_matrix(4)<=(-133.3333,0.0);				-- v4 = -2/3*Vdc;
v_matrix(5)<=(-66.66667,-115.470054);	-- v5 = -1/3*Vdc - 1j*sqrt(3)/3*Vdc;
v_matrix(6)<=(66.666667,-115.470054);  -- v6 = 1/3*Vdc - 1j*sqrt(3)/3*Vdc;
v_matrix(7)<=(0.0,0.0);						-- v7 = 0;
end process;
end Behavioral;
and the error is
* HDL Analysis *
Analyzing Entity <code_ver1> in library <work> (Architecture <behavioral>).
INTERNAL_ERROR:Xst:cmain.c:3464:1.56 - Process will terminate. For technical support on this issue, please open a WebCase with this project attached at https://www.xilinx.com/support.
Process "Synthesize - XST" failed
Can anyone help me please. I will appreciate your help.
Thanks in avance.
Mostafa
you cannot use the complex or real data type for synthesis. They are for simulation or setup purposes only.
also, your process does nothing more than set a load of constant values. it is also NOT synchronous to the clock, because you have not followed the synchronous process template.
May I suggest just doing boring old real integers first, and getting your processes sorted (i.e synchronous). After you get the hang of that you can always commence the creative data type festivities. That way you only have to solve 1 problem at a time, instead of 2 simultaneously.
Thank you for your replay. But I have a question here, what do you mean about "
I put a real and complex data as a signal, not input or output.
I'd think the same thing would still apply. Or alternatively ... have you synthesized it yet, and verified what kind of logic was created?
No, I didn't synthesized it. how can I synthesized it. sorry because I'm a beginner in this issue.
Your original error came from a synthesisor, XST. Hence I assumed you were synthesising the design.
You cannot use complex or real type in your code that you want to compile for an FPGA. you have to use bit based types.
but how can I convert the complex number to bit based type?.
I suggest starting a course on digital logic design.
take the real part and the imaginary part separately, define two signals for them, and then convert them to bit based type.
you also might need to google " fixed point + fpga".
