error code in vhdl. Can anybody help me? plz
azwaa
Hi guys!
i have problems with my vhdl code.
can you help me plz
This is the code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity correla is
port (
         clk : in    std_logic ;
         rst : in    std_logic  ;
         data: in    std_logic_vector(11 downto 0)  ;
         code: in    std_logic_vector(15 downto 0 )  ;
         Q   :out    std_logic_vector(17 downto 0) )  ;
end entity ;
architecture arch of correla  is
       type RAM is array (0 to 3) of std_logic_vector(3 downto 0) ;
       type ram16 is array (0 to 3) of signed(15 downto 0) ;
        signal CD    : RAM;
        signal temp: ram16;
        signal sum   :signed (16 downto 0) ;
        signal AB    :signed (17 downto 0) ;
begin
    CD(0) <= code(15 downto 12);
    CD(1) <= code(11 downto 8);
    CD(2) <= code(7 downto 4);
    CD(3) <= code(3 downto 0);
     étalement:process(clk,rst)
        begin
                  if(rst='1') then
                     Q  <=(others=>'0');
                     temp(0)<=x"0000";
                     temp(1)<=x"0000";
                     temp(2)<=x"0000";
                     temp(3)<=x"0000";
                   else
                        if(clk'event and clk ='1') then
                                      for i in 0 to 3 loop
                                    temp(i) <= signed(data)*signed(CD(i));
                                      end loop ;
                                      sum(0)<= temp(0)+temp(1) ;
                                      sum(1)<= temp(2)+temp(3) ;
                                         AB<=sum(0)+sum(1) ;
                                         Q<=std_logic_vector(AB) ;
                             end if ;
                     end if ;
            end process ;
 end architecture ;
error : Error (10327): VHDL error at correla.vhd(60): can't determine definition of operator ""+"" -- found 0 possible definitions
Thank you in advance for your reponse !!:-(
I think you should declare this package too...
use ieee.math_real.all ;
like this :
library ieee;
entity correla is
port (
end entity ;
        type Rom is array (0 to 3) of signed(16 downto 0) ;
        signal CD    : RAM;
        signal temp: ram16;
        signal sum :Rom ;
begin
     etalement:process(clk,rst)
        begin
                  if(rst='1') then
                     Q  <=(others=>'0');
                     temp(0)<=x"0000";
                     temp(1)<=x"0000";
                     temp(2)<=x"0000";
                     temp(3)<=x"0000";
                     sum(0)<="00000000000000000";
                     sum(1)<="00000000000000000";
                   else
                                      end loop ;
                                         AB<=sum(0)+sum(1) ;
                             end if ;
                     end if ;
            end process ;
 end architecture ;
error : Error (10344): : expression has 16 elements, but must have 17 elements
thanks a lot
The code looks nearly correct, but I didn't check for functionality.
A few corrections necessary:
signal sum0   :signed (16 downto 0) ;
signal sum1   :signed (16 downto 0) ;
sum0<= resize(temp(0),17)+temp(1) ;
sum1<= resize(temp(2),17)+temp(3) ;
AB<=resize(sum0,18)+sum1 ;
thank you my friend !
but can you give me more information about :
why exactly did you choose 17 for temp(0) not temp(1) !!?
What FVM wrote is a resize function which will resize temp(0) which is 16 bit to 17 bit,
Following is the definition of resize function -
function RESIZE (ARG: SIGNED; NEW_SIZE: NATURAL) return SIGNED;
attribute builtin_subprogram of
RESIZE[SIGNED, NATURAL return SIGNED]: function is
"numstd_resize_sns";
-- Result subtype: SIGNED(NEW_SIZE-1 downto 0)
-- Result: Resizes the SIGNED vector ARG to the specified size.
-- To create a larger vector, the new [leftmost] bit positions
-- are filled with the sign bit (ARG'LEFT). When truncating,
-- the sign bit is retained along with the rightmost part.
Because the the "+" function ensures all inputs are the same length before adding. So temp(1) is also extended to 17 bits.
Thank you :wink:
error.PNG When I made the simulation :
Normally, the results will be : 1 1 -1 1 -1 -1 1 -1 1 1 -1 1(Multiplication between data and code)
As said, I didn't check the code serves a reasonable purpose. You have posted so many functionally different VHDL codes claimed to solve the same problem that I gave up to figure out what they are exactly doing.
I suggest to watch all intermediate signals in the simulation to understand how the result is generated,
Okey ;;
Can you help me !
Why don't you write down an example with input, expected intermediate results and output data? You can use it also to check the calculation steps in simulation yourself.
Presently I don't even understand the presentation of simulation data. Why do you split Q into 3 decimal numbers instead of displaying it binary?
Here is the schema what I did :
Thanks a lot :sad:
I have seen the diagram before, it's a bit vague. I appreciate an example with data values.
Hi!
plz Do you have any idea about Desetalement of spectre in VHDL ?!
