sajjaudaykumar
Junior Member level 1
Hi All,
First of all thanks for all your inputs. I am using encounter_test for the first time(worked with TK and fastscan all my life). I am having hard time understanding the use of experiment in various ET commands like create_logic_test and commit_tests. One example is I run an experiment exp_scan and take the design through the whole phase until create_patterns.
Then if I come back and try to rerun with the same experiment name the the create_logic_test fails giving the msg can't use the experiment name again. Can any one explain the usage of the experiment name? Do I need to delete the database before a fresh run?
Help will be appreciated.
