does anybody can help me recognise this PCB file.
hyoree
Member level 1
Member level 1
is anybody can help me recognise this PCB file?
which PCB soft can open or translate this PCB file?
many thanks!!
Re: is anybody can help me recognise this PCB file.
i think i might be PCB123 i am not sure r else try opeaning it with any gerber viewer.
PFW.PCB
Protel For windows
M
i uninstalled PCB123 last month, is anybody can help me prove that PCB123 can open this PCB, thank you!
majnoon, "P*otel For windows" means what?
potel2004 /protelDXP or another soft?
Added after 1 minutes:
i uninstalled PCB123 last month, and deleted the setup file.
majnon, i have downloaded the protel for windows v2.5, but it can't open this PCB file.
give me some suggestions, friend.
Inside the file you have posted there is a line says PFW.PCB
which stands for Protel For Windows.
Could it be file has been corupted?
Regards,
M
    hyoree
Its not protel 99se file or older nor Pads expedition pcb file. I don't have pcb 123
I need to check on Altium since file contains pfw.pcb
Nishal
It definitely is an old Protel ascii file, but it appears to be corrupted - it should be all ascii, but a portion of it is binary.
SiGiNT
what do you mean?
i just want to know whether it can be opened and translated?
I don't think so, is it possible to get another copy of the file? If you can it can be qpened by Protel 94 - find in fileman, the downloads section.
SiGiNT
If the file is an ascii, try making a copy of PFW.PCB
rename it PFW.asc. Now try IMPORT PFW.asc.
Mack
PCB Layout Blog
