does anybody can help me recognise this PCB file.
hyoree
is anybody can help me recognise this PCB file?
which PCB soft can open or translate this PCB file?
many thanks!!
Re: is anybody can help me recognise this PCB file.
i think i might be PCB123 i am not sure r else try opeaning it with any gerber viewer.
PFW.PCB
Protel For windows
M
i uninstalled PCB123 last month, is anybody can help me prove that PCB123 can open this PCB, thank you!
majnoon, "P*otel For windows" means what?
potel2004 /protelDXP or another soft?
Added after 1 minutes:
i uninstalled PCB123 last month, and deleted the setup file.
majnon, i have downloaded the protel for windows v2.5, but it can't open this PCB file.
give me some suggestions, friend.
Inside the file you have posted there is a line says PFW.PCB
which stands for Protel For Windows.
Could it be file has been corupted?
Regards,
M
    hyoree
Its not protel 99se file or older nor Pads expedition pcb file. I don't have pcb 123
I need to check on Altium since file contains pfw.pcb
Nishal
It definitely is an old Protel ascii file, but it appears to be corrupted - it should be all ascii, but a portion of it is binary.
SiGiNT
what do you mean?
i just want to know whether it can be opened and translated?
I don't think so, is it possible to get another copy of the file? If you can it can be qpened by Protel 94 - find in fileman, the downloads section.
SiGiNT
If the file is an ascii, try making a copy of PFW.PCB
rename it PFW.asc. Now try IMPORT PFW.asc.
Mack
PCB Layout Blog
