Documentation Layers in PCB Layout
Veronika
Member level 2
I have difficulties in understanding the purposes of the Documentation Layers such as Silkscreen, Soldermask and Solderpaste. What are they for and where should I set them?
Which of them should I specify when creating the PADS Decal, for example, FPGA?
poorchava
Advanced Member level 1
Wrocław, Poland
ok, one by one:
Silkscreen is the layer which contains whatever markings you want to have on your board (like, component designators, component orientation hints, high voltage warnings, hints for troubleshooting (eg.g 'this should be at 1.23345V' ), wild african animal pictures, design revision number, website, your name, basically whatever you like to)
Soldermask is the thermoresistive lacquer which covers all of the pcb excluding soldering pads and usually vias. This is to prevent oxidation/degradation of copper and to solder components more easily/reliably. What is actually specified in Gerber files are openings in soldermask rather than mask shape (so you mark where soldermask should NOT be).
Solderpaste works similar way as soldermask. It depicts opening that you would have to make in screen printing stencil to print proper amount and pattern of soldering paste. Stencils are usually done only for volume production.
I don't use PADS so I dunno where to look for these options. Generally in most software Soldermask openings are defined along with pad definitions and design rules. You can of course add additional soldermask openings (for whatever reason, e.g. sometimes silkscreen is not used so you can place an easily readable part number on pcb as opening in soldermask)
Solder paste stencil openings work in similar way. In simple cases (like standard 0805 passives) they are more or less similar to soldermask openings. In more complidcated cases (especially heatsinked packages like TO-252 and TO-267) there may be need to "chop" stencil opening into smaller pieces to provide thinner layer of solderpaste when component is placed.
king.goku
Junior Member level 3
Coimbatore, India
SILK SCREEN - It is nothing but a layer which uses names, outline and symbols for the components that are used on top and bottom side of the PCB.
SOLDER MASK - It is a coating which prevents solder wetting during manufacturing. On a finished Pcb it protects traces from physical damage, Chemical reaction and also minimises stray capacitance. Sometimes it is used in both sides(Top & Bottom).
There must be clearance(keepout area) allocated in Solder mask layer for the components and mounting holes. Traces or components must not pass through Solder Mask.
