Digital circuits at high frequency?.......
walkman
Member level 1
Member level 1
hyderabac
i am currently working on high speed interconnects i want to why we cant operate(use) digital circuits at high frequencies(ex:15Ghz)and why we are going for analog circuits for high frequencies?
Thanks in advance.
Thanks in advance.
Are you referring to the High-Speed Transmitter/Receiver for I/O interfaces or are you referring to core Transmitter/Receiver?
digital circuits are composite circuit blocks using switching elements of various types. Each of these elements has a capacitance of some amount which CANNOT be reduced below some minimum limit (depends on the technology). Hence the circuits are unable to 'switch' faster than a corresponding maximum.
This is also one of the reasons that lower switching voltages are used to help speed things up.
