Not exactly. Maybe what you are describing can be performed with additional tools/effort. XL holds information between the schematic and the layout. So insted of opening again the library and select the layout view of a cell that you have used in the schematic and configure its properties you can select this component in the schematic and place it in the layout with exactly the same properties. Also you can see in the layout the connections that you must do based in the connections that you provided in the chematic.p_shinde said:hmm schmatic elements directly to mask layout????????? no need to draw it manually? so it would be like place and route with standard cells, if i am rgt.
thanks,
Prasad
