Designing a preamp for photodiode, signals are lost
subha98
Newbie level 5
Ann Arbor
I am designing a preamp for photodiode. I ac couple the signal from diode and feed into transimpedance amp. but when I provide a DC leakage current path through a high valued resistor to ground,my signals are lost.
Why does providing a DC leakage current path to ground does not work for higher values of leakage current?
Leakage current path
Maybe you have much surface leakage! Use guarding technique!
Good info source is for in 6th Eddition:"Low Level Measurements" a book (& 2-3 others too) from Keithley, you can order it free & over Webside:)...
Some circuits technique is descripted by ADI & older BurrBrown literatures(yet TI)...
What about over leakage in coupling capacitor?
Second source of your signal lost is maybe the bandwidth limitation through (very)high resistances & stray capacitances!
You can check for a feedback realized as a "T" structure...Described(I belive)in TI`s ApplNotes.
K.
Re: Leakage current path
I cannot visualise what you are describing. A circuit diagram would probably help.
Keith
I think the diode is biased over a serial res. & so comes with AC-coupling to the amp, but a circuit will be better to see...
K.
depends on your diode, but high speed photodiodes like to be reverse biased to work right. A leakage path would bleed off the reverse bias?
The diode is reverse biased. Yes, the leakage current does limit the biasing that can be applied although the resulting bias voltage should be enough to generate a signal upon interaction.
What provides the DC bias point for the amplifier?
Keith.
DC power supply for the amp is external(+5v) and is diferent from the diode bias supply, which a lot higher ( upto 50V)
That doesn't explain what the transimpedance amplifier circuit looks like and where the input bias current for it comes from. It is difficult to help with so little information.
Keith.
The TIA I use is SFT-0100 and works fine without the DC path resistor. My question is regarding this 22K resistor..is it causing a discontinuity that it is reflecting the high freq. components of the pulse, and hence TIA is not able to sense the smaller signal? How does increase in leakage current ( which is a DC current with some modulation) affect things further.
I am still struggling to understand what you are doing. I am surprised you don't have a proper diagram to show. Your connection diagram, such as it is, shows no DC path for the photodiode except the 22k resistor. As the TIA is an 8GHz device I would expect it to either be connected directly to the TIA input, or to have its own load resistor of maybe 50 ohms.
You cannot really go coupling 8GHz through a 0.1uF capacitor - at best it will look like an inductor above a few MHz.
Keith.
Its a ultra high BW coupling cap of pass band os 100KHz to 16 KHz. Anyway thanks.
Added after 40 seconds:
Iam sorry for the typo...pass band till 16GHz.
A 16GHz 100nF capacitor? I would be interested in the details of that.
You didn't reply to my other comments.
Keith
Hi Keith,
I was supressed too, but (I think) past week gave somebody on another topic a link over such AVX types, after that I found from AVX & ATC datasheets(maybe their are only from ATC)...
It exists only as 100nF!:)
K.
karesz,
Thanks. I dread to think how much they cost! I usually end up having to parallel a few smaller capacitors to get good HF performance (although don't usually need 100nF at 1GHz!). Even "normal" microwave capacitors can be expensive.
Keith.
I think the more old school (more values parallel) is better of HF quality, but need more plaace...
K.
K.
It may be "old school" but normal capacitor cost = 0.02 UK pounds, microwave capacitor = 0.68 UK pounds! So, you can see why I use normal capacitors!
Keith.
ATC has broadband and ultra wide band MLCs at 100nF value:
