Oct 5, 2010 #1 R Rcy Junior Member level 1 Joined Sep 17, 2010 Messages 16 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,283 Activity points 1,389 I have designed a folded cascode opamp.... so if i connect a feedback resistance and an input resistance to the inverting terminal, will it act like an inverting amplifier.....
Oct 5, 2010 #2 erikl Super Moderator Staff member Joined Sep 9, 2008 Messages 8,108 Helped 2,695 Reputation 5,370 Reaction score 2,305 Trophy points 1,393 Location Germany Activity points 44,123 Sure, if your operation points are correct (inputs within common mode range). Care for enough phase margin if you use it in low gain configuration.
Oct 8, 2010 #3 S steve_guo Member level 1 Joined Sep 29, 2004 Messages 35 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,288 Activity points 183 u'd better to have a driving stage to drive resistor load unless it is large.
Oct 8, 2010 #4 samiurrehman Member level 2 Joined Aug 30, 2010 Messages 49 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,288 Location Pakistan Activity points 1,729 cascode structures drastically decrease the output signal swing.....make sure your circuit performs as desired......
