Lightning19
Junior Member level 2
Hello,
I downloaded an AES package off of OpenCores, and am trying to synthesize it with Design Compiler.
I am currently trying to synthesize a file key_expansion.vhdl with
read_vhdl "key_expansion.vhdl"
However I am getting an error message
[Failure] Entity declaration KEY_EXPANSION not found in library WORK
*** Presto compilation was unsuccessful. ***
Error: Can't read 'vhdl' file '/...l/keyexp/key_expansion.vhdl'. (UID-59)
At the top of the key_expansion.vhdl file, there is
library WORK;
use WORK.aes_pkg.ALL;
and there is a directory called work that contains an aes_pkg directory with .dat, .dbs, and .prw files.
How can I get Design Compiler to recognize these files so that it can synthesize this file?
I have tried
define_design_lib WORK –path ./work
but unfortunately this did not correct the problem.
Thanks.
library WORK;
I have tried
Thanks.
