Darkroom Timer Project - changes needed
electronicus
Full Member level 4
Romania
darkroom timers
I build this project and work wery well https://www.electronics-lab.com/projects/oscillators_timers/019/index.html But I wish to change the display connected to pin 7 (RB1) to count over 10 not over 6. I tried to change te "asm" file but without result. I are novice in writing programs for microcontrollers. can someone help me ? I attached archive containing all files needed. diagram is drawn with Proteus
v7.5 SP3.
Thank you very much !
wp100
Advanced Member level 5
Prime Meridian
darkroom timer project
Have not run this code, but if you look at it you will see the two lines that need changing to turn it into a seconds counter - hopefully that will make it work as you want.
