Mtech1
Junior Member level 1
I've come across the concept of controlling LED brightness with PWM (Pulse Width Modulation) using a microcontroller. I looked that adjusting the duty cycle from 0% to 100% is involved in controlling LED brightness. However, I'm looking a clear understanding of the principles behind it, particularly the role of the timer. Researching several sources, I'm still not entirely clear on this.
Thank you in advance.
Generating PWM using PIC Microcontroller with MPLAB and XC8
In this tutorial we learn how to generate PWM signals using PIC PIC16F877A. PIC MCU has a special module called Compare Capture module (CCP) which can be used to generate PWM signals.
circuitdigest.com
