D/A IC Voltage Problem
Zerox100
Full Member level 6
Dear All,
I should design a Inverter controller that need a 0~10v input. But we have a controller that have a 5v power supply. Is there any D/A IC that work with 5v and provide 0~10v or higher ouput?
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
No. You will need to provide a 10V supply (which can be from a simple doubler IC) and either a 10V DAC or a 5V DAC followed by an amplifier.
Keith.
Zerox100
Full Member level 6
Dear,
Could you please give me an example of doubler IC?
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
All these are capacitive charge pumps - either doublers or inverters. Some can be either. **broken link removed**
There are other makes, eg National, Harris/Intersil
Keith.
bobcat1
Hi
Just applay the 5V D/A output via a 2X amplifier (opammp) with proper power source (12V VCC min)
bear in mind that the converter output is dabbled
All the best
Bobi
Zerox100
Full Member level 6
Can i use +15v from an max232 converter
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
I think they only produce 10V maximum, not 15V, but yes it is possible. The only snag with any of those sorts of converter is the potential noise ont he supply. They are also usually unregulated so as the load increases the voltage drops. A regulated output DC-DC converter would be best but then they cost more and take up more board space. You can design your own DC-DC converter (inductive switching) with regulation. National Semiconductor's WebBench is one place to start.
Keith.
