Crosstalk effect in IC...
sohiltri
Member level 5
"RElative high output impedance makes the circuit very sensitive to crosstalk "....
Can anyone explain me how???
amriths04
Full Member level 5
incase your adjacent wire's impedance is higher than your wire's impedance, then there will be a larger amount of electric field(analogous to voltage drop) across the higher impedance giving rise to cross-talks.
A.Anand Srinivasan
Advanced Member level 5
India
i dont understand what you are trying to ask... are you talking about IC pins are adjacent wires....
sohiltri
Member level 5
No ....
it speaks for any gate high output impedance makes circuit very sensitive to cross talk in book Rabaey.....
can u explain crosstalk wrt this staemant also???
A.Anand Srinivasan
India
crosstalk is the phenomenon of the signal from a adjacent line getting coupled... the main idea here is that a small current across a high impedance causes a lot of voltage...
whenever a gate or something switches it consumes a lot of current and after switching this leads to the peaking up of current throughout the circuit (ringing current) and hence this causes significant change in the gates with high impedance...
this is why TTL gates which are not used are generally tied high or low(suitably)...
