ASIC_int
1) Y= '0'.
2) The netlist should not be a 2:1 mux. It is because casex is synthesizable. So it will try to produce a gate level structute where even if in='X' , the output should be 1'b0. Si the tool will try to look for gate in the library that can realize such a gate level netlist. So Y= '0' when in= x.
lostinxlation
lostinxlation
You still did not reply the following:
"A casex treats X as don't cares if they are in either the case expression or the case item".
What does it mean to state that casex treats case expression as don't care?
lostinxlation
lostinxlation
