tienchuan
Newbie level 2
Hi everybody![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm doing a project with PIC to check connection of wire hardness.
A wire hardness have two housing, once housing have a 32 pins, connection parallel from one pin of 1st housing to one pin of 2nd housing.
I'm building a circuit using 4 shift register IC ( 74HC595) to output and using 4 74HC165 IC to input as a schematic included below this post.
About an idea to programing, I think I shift one bit to output, and check on input pin, if data right, i'll change to next step.
Because this circuit is using in noise zone, sothat I need a recommend to check a design again.
Please show me if it not correct.
Thanks you.
![Capture.JPG Capture.JPG](https://www.edaboard.com/data/attachments/56/56808-087a016298025180eb4f9e3d35bafcf2.jpg)
View attachment Wire_Hardness_Checking.pdf
Thanks you.
