xtcx
Advanced Member level 1
- Joined
- Dec 22, 2007
- Messages
- 493
- Helped
- 65
- Reputation
- 130
- Reaction score
- 58
- Trophy points
- 1,308
- Location
- Bangalore, India
- Activity points
- 5,003
Hello guys, I'M using chipscope pro 8.2 version. I have monitored the pin or buffer inside FPGA by assigning the ports and triggers and clks. Now when running "Analyse using Chipscope", I can read the data from the desired registers as a time basis, that is I can only view a few set of samples (512 or 1024 upto 16384) which were selectable while we insert the core using ICON. So now I need to trigger each time when I wanna check the data in pins. In my organization, they've askd me to check if this tool can be used as a logic analyser?(Continous signal monitoring),whereas I am able to check the data on trigger basis(Capture and compare). Please some clarify my doubt about chipscope's functionality shortly.Thanks for any of your response
