Can I use DTMF tones to provide a 1400Hz hand shake and kiss off tones?
JohnJohn20
My alarm panel will call my mobile phone when it is activated. However, to acknowledge that I have received the notice, and so stop the alarm panel from resending the alert, I need to reply with a 1400 Hz hand shake kiss off signal tone.
If I press the [3] button on my phone, this will generate a DTMF 1477 Hz and 697 Hz tone. Will this be close enough to the required 1400 Hz signal to provide the hand shake and kiss off?
Or is the only alturnative to have a 1400 Hz tone generator which I hold up to phone microphone?
Thanks.
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
The difference between 1477 and 1400 Hz is 5.5 percent. It's possible your alarm panel can detect a tone within that bandwidth. (Even with the 697 Hz tone playing at the same time.) It's the kind of thing where you have to experiment.
Or, you might obtain a whistle (pitch pipe, etc.) that produces 1400 Hz. That's 'F' two octaves above middle C.
Or, if you can remember how a 1400 Hz pitch sounds, and you whistle it, the alarm panel ought to detect that. Try gliding your whistle up and down around the pitch, and it could hit the right tone.
JohnJohn20
Thanks. That was what I thought but before experimenting it seemed a good idea to get a bit of background.
xxtigerxx
Advanced Member level 1
Greece
didi it work?
because i think you must have good accuracy at the frequency like +-5% for the kissoff frequency.
JohnJohn20
Haven't tried yet. I will have to wire it up on the bench and give it a test. I will let you know.
