alfie.max15
Member level 2
It's really two circuits divided by the ground connecton in the middle.
The top is a signal generator, you have to produce pulses in software to drive it. The bottom is a receiver, producing a signal the software can read.
Your software would normally produce a burst of pulses at ultrasonic rate (typically 40KHz) and then start a timer. The timer stops when the receiver section picks up the echo. From the time delay you then work out how far the sound travelled and divide it by 2 to get the distance to the reflector.
You should note that with the values shown, the transistor is always conducting. It would be better to design it so the transistor only conducts when necessary.
Brian.
My guess is this design is someones idea that never reached the debugging stage.
[/I]
i'm sure it has been tried out.
Trust us, its a bad design. Other than it's only good feature : that it is very very very simple - connects directly (almost) to the uC.
There are plenty of much better circuits & designs out there. Look for them.
i just cant make anything seeing the circuits...
