Aug 23, 2018 #1 P Puppet123 Full Member level 6 Joined Apr 26, 2017 Messages 356 Helped 22 Reputation 44 Reaction score 21 Trophy points 18 Activity points 3,059 Hello, I am using Cadence Virtuoso 1.6.4. In the newer versions of Virtuoso, there is an option in the LSW for Layout where you can select only the routing layers. Are the routing layers basically the metal layers - ie. M1, M2 etc in the PDK ? I want to use this feature in the older version of Virtuoso I have so I wanted to check what this function did. Thanks.
Aug 23, 2018 #2 T ThisIsNotSam Advanced Member level 5 Joined Apr 6, 2016 Messages 2,549 Helped 397 Reputation 794 Reaction score 464 Trophy points 1,363 Activity points 14,766 Puppet123 said: Hello, I am using Cadence Virtuoso 1.6.4. In the newer versions of Virtuoso, there is an option in the LSW for Layout where you can select only the routing layers. Are the routing layers basically the metal layers - ie. M1, M2 etc in the PDK ? I want to use this feature in the older version of Virtuoso I have so I wanted to check what this function did. Thanks. Click to expand... routing layers are a function of the technology and metal stack. in legacy nodes, poly was routable. these days you have some M0 layers that are routable, some that aren't. Some M1 layers are restricted, etc.
