Larger blocks means opamp,ADC something like that? But in mostly every circuit inverter is used. If in inverter,all the errors are not removed then how come other complex layouts will be error free?
Which contacts are redundant? Wherever their is an intersection of M1,M2 or M1,GC or any other, contacts are needed?
I have also noticed that if I am only using M1 not M2,then M1 are crossing(intersecting) each other but no error is displayed. Is it the right way?
Then how did you solved all this errors?
