Thanks for the quick reply.
I am using VT Standard Cell Library and there is no *.v file containing all the gates such as and, inv etc used in the synthesized netlist.
So, how do I point to the library gates when I have the synthesized netlist, sdf, and *.lib file but no verilog file with all gate descriptions such and2_1 or nand etc. used in the synthesized netlist.
To be more precise, I get the errors like the following one in Cadence, when I compile the synthesized netlist, annotate the sdf file in the testbench and then use ncelab command.
and2_1 g631(.ip1 (B[8]), .ip2 (n_15), .op (c_out));
ncelab: *E,CUVMUR (./gen_ks_sa1.v,1817|12): instance 'test.ks_sa1_1.d9_1.a9_1.g631' of design unit 'and2_1' is unresolved in 'worklib.adder_ks9:module'.
