eklikeroomys
Full Member level 3
- Joined
- Oct 11, 2010
- Messages
- 150
- Helped
- 40
- Reputation
- 80
- Reaction score
- 38
- Trophy points
- 1,308
- Location
- South Africa
- Activity points
- 2,132
Halo,
I am using Cadence ELC to characterize a new standard cell library. When I run the tool, it completes up to the point where it is supposed to start simulating, then the problems start, as you can see from the log below:
elc> db_spice -s spectre -keep_log
[WARNING(db_spice)]License for paralled mode is not found. Entering non-parallel mode
DESIGN PROCESS #ID STATUS IPDB
[WARNING(db_spice)]No spice simulation to do, please check the cell/process list for any error
elc> db_output -lib out.lib -process typical -state
[WARNING(db_output)]No such process : typical
[WARNING(db_output)]No output data generated, please check the cell/process list for any error
elc> db_close
Database : library is closed
elc> exit
Can anyone please help me, I am not sure what the problem is
thank you
elc> db_close
elc> exit
thank you
