eng.amr2009
Junior Member level 3
- Joined
- Dec 21, 2009
- Messages
- 25
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Egypt
- Activity points
- 1,509
Guys,
In case I use a post APR or post Synthesis netlist in simulation without SDF annotation, I receive timing violations as the timing checks are performed based on default timing in standard cells behavioral model.
I know of a modelsim option called +notimingchecks which is added to vsim arguments to disable timing checks globally. However, my Question is
Does it only disable timing checks and still the outputs are evaluated after the default gate delays ?
Or the gates are treated as RTL where logic have zero delays ?
If they are not treated as zero delay, then how can I instruct Modelsim to assume zero delays and ignore timing specs in std cells behavioral models ?
note : I do not have the RTL for this netlist and I do not need to run timing simulation. It's just included as a submodule in an all-RTL design.
I'm using TSMC 180
Quetsasim 10.3
I'm using TSMC 180
Quetsasim 10.3
