bitprolix
Junior Member level 2
- Joined
- Sep 19, 2013
- Messages
- 24
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 235
Hi All,
I'm a newbie in the digital modelling world and I'm really keen on learning it. As part of the college curriculum, i've been given a task to model an elevator whose functioning is mentioned **broken link removed**, I've been working on it, but haven't been successful so far, as I had no prior knowledge of this subject and hence I'm struggling as of now (Though I have improved over past few weeks). To solve this task, I came up with the below code, but unfortunately my cart doesn't move so I don't see any transition in the waveform. I don't expect any direct answers for this task as that would defy the reason for taking this course, but some kind of direction or feedbacks would really help me to proceed further. The testbench is already provided in the above link. My current incorrect code is as below :sad:
Thank you for your help.
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_signed.all;
use IEEE.std_logic_unsigned.all;
entity Elevator is
generic ( NUM_FLOORS : positive);
port ( BUTTONS_IN : in bit_vector ( 1 to NUM_FLOORS );
BUTTONS_OUT : in bit_vector ( 1 to NUM_FLOORS );
DIR_UP : out bit;
DIR_DN : out bit;
DOORS_OPENED : out bit_vector ( 1 to NUM_FLOORS );
MOTOR : out bit_vector ( 1 downto 0 );
FLOOR_NUM : out integer );
end Elevator;
architecture Behavioral of Elevator is
-- used for IPC
SIGNAL request: bit_vector(1 to NUM_FLOORS);
-- SIGNAL current: bit_vector(1 to NUM_FLOORS);
SIGNAL rq_move: bit;
TYPE ENUM IS (up, down, stationary);
SIGNAL cart_dir: ENUM := up;
BEGIN
-- While the cart is moving up/down and doors are getting
-- opened, store the latest requests coming from differnt
-- floors.
cart_snooping: PROCESS( BUTTONS_IN, BUTTONS_OUT)
BEGIN
request <= BUTTONS_IN or BUTTONS_OUT;
end process cart_snooping;
-- take action on the request
take_action: process
VARIABLE i,j: INTEGER;
VARIABLE floor_to_service: BIT_VECTOR (1 to NUM_FLOORS);
VARIABLE tmp_request_var: BIT_VECTOR (1 to NUM_FLOORS);
--Assuming the cart is stationary on 1st floor in the beginning
--XXX: How to get across this assumption
VARIABLE current_floor: INTEGER := 1;
VARIABLE current_floor_tmp: INTEGER := 1;
VARIABLE motor_state: ENUM := stationary;
VARIABLE doors_opened_var: BIT_VECTOR(1 TO NUM_FLOORS);
BEGIN
tmp_request_var := request;
CASE motor_state IS
WHEN stationary =>
DIR_UP <= '0';
DIR_DN <= '0';
FLOOR_NUM <= current_floor;
DOORS_OPENED(current_floor) <= '1';
MOTOR <= "00";
WHEN down =>
-- first service, requests from lower floors
FOR i IN current_floor TO 1 LOOP
IF (tmp_request_var(i) = '1') THEN
DOORS_OPENED(i) <= '1';
DIR_DN <= '1';
DIR_UP <= '0';
current_floor_tmp := current_floor - 1;
MOTOR <= "01";
wait for 5 sec; -- open the doors for 5 seconds
END IF;
WAIT FOR 1 sec; -- time elapsed in moving from one floor to another
FLOOR_NUM <= current_floor_tmp;
END LOOP;
cart_dir <= up;
WHEN up =>
FOR i IN current_floor TO NUM_FLOORS LOOP
DIR_DN <= '0';
DIR_UP <= '1';
MOTOR <= "10";
current_floor_tmp := current_floor + 1;
END IF;
END LOOP;
cart_dir <= down;
END CASE;
FOR i IN 1 TO NUM_FLOORS LOOP
IF (request(i) = '1') THEN
cart_dir <= down;
END IF;
END LOOP;
motor_state := cart_dir;
end process take_action;
end Behavioral;
