Bandgap and Process variation
suhas_shiv
Full Member level 2
Hi all.
How do you design a bandgap which takes care of not only temperature but process variation also? What I mean to ask is, is there any specified circuit topology or something like that? Could anyone please throw some light into this?
Thanks
eecs4ever
Full Member level 3
Analog Environment
You can design bandgap circuits that are relatively immune to temperature and process.
The effects of temperature is stablized by canceling Vbe (which goes down as Temperature goes up), and Vt (or delta Vbe) <--- goes up as T goes up .
The effects of process variation is contained by matching up components. So that the W/L and Un Cox "Cancel".
See the following power point:
https://oevlsi.ece.cornell.edu/ECE453/Fall2005/projects/Bandgap.ppt
For more details, refer to Grey and Meyer, pg 317.
Good Luck!
jonneylu
Member level 1
bandgap depend more on temperature than process.
you can read some paper on IEEE
johnsmith101
Member level 3
The key is to use matched devices. Pay particular attention to layout.
