Asynchronous D flip flop with preset and clear
BB11
Member level 4
india
Hello
Can you please confirm if this is the circuit diagram is correct for Asynchronous Positive edge triggered D flip flop with preset and clear? I am not getting expected results only for 1 condition : when Preset =1, clear=0 -- expected output Q=1 but it shows Q=0.
Can you please advice?
Preset = 1: since Preset is LOW active --> Preset is not active
Clear = 0: since Clear is LOW active --> Clear is active
So when Preset is not active, while Clear is active, I expect Q to be 0.
Hello
Please check this output
I´ve had a quick view. I found nothing unusual with the FF behaviour.
..But with your test setup:
* CLK is slower than other signals. Does this make sense?
I assume your test setup is not very useful. --> make CLK the fastest signal or setup for special cases
Reactions: BB11
    BB11
Thank you.. I will update the clock
