linaweku
Junior Member level 1
so plz,
any body to help me to desgin a code for
Title : Multimedia Application
Problem Description
You are required to create a Multimedia application that generates a calendar of the year, and at the same time be able to select a particular date and display the time. In a addition, your application will be able to select a wave (*.wav) file and subsequently play the file. Your application should also be able to stop the play and close the application.
Problem Description
